Brief Description: Fuel Tank Vent Modification, checked Emp. bolts
Went back to the steps I had skipped and need to finish.
37-08: Fabricated the Fuel Vent Air Line by cutting 3 different sizes of plastic tubing and connecting them to the FLF-0006 (plastic T). Fabricated the T-01219B and T-01219C Fuel Vent Lines. Primed the F-1296 Vent Bracket and then riveted it to the F-1207C-R Bulkhead. Installed an Adel clamp to the bracket and snap bushings in the holes in the bulkhead and F-1282-R Skin. Will finalize this page after the TC is riveted to the Fuselage.
06-07: Rechecked the AN3 bolts on the V-Stab and those attaching the hinge hardward. Tightened those that were not tight and torqued all of the bolts to 25 in-lb. Did the same to the H-Stab bolts. Applied torque seal on the bolts.
33-04: Cut 2 inch X 3 inch anti-slip material and applied on the steps.
