Brief Description: Glued the Canopy Fairing to the Fuselage
Installed the Canopy Fairing to the Fuselage and Canopy using Permatex Right Stuff. Taped the fairing to the Fuselage as tight as possible while the sealant is curing. Worked on the Canopy Handles and Latch. The latch is too tight despite the correct measurements. Filed the top of the tube where the handle goes through a little bit without much change. I'll see if I can get a thinner nylon washer to put between the handle and the Canopy Frame.
