When trial fitted, the Canopy Fairing still seems to bulge outward. So, I sanded the the Foams some more. Removed the plastic washers I had previously installed between the Fuselage and the Canopy Frame pivot point to see if this will lessen the outward "bulge" of the frame. It seemed to helped a little. The aft hole of one of the Gas Strut broke when I removed the bolt securing it. I should have remove the bolt at the pivot point first. Will need to get a replacement strut.
