Brief Description: Trial fit of Canopy Latch, riveted Latch Block
Got a new WD-1218 Canopy Latch and match-drilled #19 the tube through the C-656 Canopy Handle. Despite ensuring accurate measurement between the Latch and Handle, it is still a tight fit. I could latch the handle but it is hard to unlatch. I could file the C-1205 Latch Block a little bit but I'm not sure if that would work. I'll work on this later. Filed the edges of the C-1214 Latch Block and then riveted it to the F-1231 Latch Plate. Initially used LP4-3 rivets but drilled them out and replaced with LP4-4 after I discovered the error.
