Went back to previous steps that I had skipped. Applied foam strips on the F-12125 Over Rudder Wireway. I noted that I had routed several wires to the right of the F-1235A Inbd Rudder Pedal Blocks. Therefore, I had to disassemble the rudder pedals assembly to reposition the wires. It was hard to reach the bolts securing the assembly and there is interference from the rudder pedals. Since the landing gear is installed i can no longer turn the fuselage on its side. I had to disconnect the brake lines to make the work a little easier. It was time consuming to fix this minor error. The Over Rudder Wireway and F-12125C Wireway Bracket Flange were very difficult to install because they are so far forward and I can only use 1 hand to reach them. Got into the cockpit and despite contorting my body, I still could not easily do the work. Tried to put zip ties around the wires but was not successful after multiple tries. I'll postpone this task for later. I still need to route the static line after I connect the Tailcone to the fuselage. I'm almost tempted to put the pitot tube on the wing so I don't have to route the pitot line thru the tunnel and to the top of the Panel Base. Today was not very productive for plane building.
