– Transferred the drill template back to the right side of the Center Section Assembly and final-drilled ¼ holes including the Outboard Doubler and Wear Plates. Countersunk the U-1202D-B Outboard Wear Plates using an inexpensive Drill Press that I purchased from Harbor Freight. Primed the Outboard Doubler and Wear Plates and the U-1202E Inboard Doubler Plates.
