Brief Description: Fabricated Servo Pushrod Assemblies, Static line w
Section 29-06: Riveted the hinge half to the Map Box Door. Used flush head rivets to match the flush head screws in the panels. Used AN426AD4-4 rivets.
Section 44A-02: Fabricated Roll Servo and Pitch Servo Pushrod Assemblies by cutting aluminum tubing per the plans and then enlarging the holes at the ends followed by tapping 1/4-28. Installed M3414M rod end bearings to the holes.
Section 42D-12: Updated the static line by cutting it at the middle and installing the F Plastic Tee and attaching new lines (F-00013, F-00015 and F-00012).
Painted the Seat Floor Cover, Baggage Floor Cover and Baggage Cover with a hammered silver finish. Deburred the F-1207F Baggage Bulkhead corrugation and the F-1227 Seat Ramp cover.
