Brief Description: Installed tire on one main wheel
Split one main wheel assembly. Had difficulty passing the valve stem through the inner wheel half. I later realized that I had to unscrew the wheel hub to do this. Reassembled the inner wheel half (with the wheel hub) with the outer wheel half after placing the tube into the tire. Reinflated and deflated several times for proper seating. I will finish the other wheel later.
