Brief Description: Installed auxiliary audio output jack
Received the optional auxiliary audio output jack from Van's today. Soldered 47 Kohm resistors to the 2 extra wires from the co-pilot headphone jack. Soldered each resistor to the aux audio output jack and then activated heat shrink tubing over connections. Installed the 3 jacks to the right Seat Ramp Floor. Routed the C-P Headset Harness through the snap bushings all the way to the front of the fuselage.
