Brief Description: Routed cables from panel to center section
Skipped the section on wing installation until the weather is good (I have to do it outdoors) and help is available. Since I'm planning to install the Dynon Skyview option, I skipped the steps on preparing the terminals. Started with Step 6 of Section 31-02 by modifying a grommet (enlarging the hole) using a socket and vise and then then installing it in a firewall penetration. Spent a lot of time preparing for Section 31-03 because I had to locate the various parts needed that were in different hardware bags. I did more detailed parts inventory whenever I opened a bag and separated and labeled the parts. One bag was missing certain nuts. Drilled a hole in the center of the corrugated duct to make the F-1204Y Wire Run Conduit. Ran strings in the conduit per plans. Attached the conduit to the Center Section Assembly using 4 cushion clamps. Final-drilled a cushion clamp and bolted it to the F-60 Fuel Flow Sender. Routed the WH-RV-12-SL-ANT and WH-RV-12 TX-ANT cables and phone cable from the Panel Base to the center section assembly through the cushion clamp and bulkhead snap bushings.
