Riveted the F-1207E Shoulder Strap Lugs to the Tailcone. Riveted the 2 rows of holes that are common to the TC, Fuselage and Baggage Corner Skins. Also riveted the open holes in the F-1280A and F-1270B Doublers, the lower part of the F-1270 Fuse Skins and Baggage Corner Skins. There are still unriveted holes in the bottom aft of the fuselage and forward of the tailcone (side and bottom). Not sure if they can be riveted now but will check the instructions before proceeding.
Organized the wires in the tunnel and secured with zip ties and lacing tape. There are 2 white wires in the tunnel (L458 and L456) that are not connected and I'm not sure if they are still needed or where they should go. They are part of the old harness before the SV wiring upgrade. I pulled them into the tunnel where the fuel shut off valve is, rolled them, applied heat shrink to the ends and zip tied them to the wire bundle.
