Brief Description: Installed new fuel lines and tightened fittings
Installed the new F-1259F Fuel Line Tank and F-1259H Fuel Return Line Aft. Applied loctite 567 thread sealant to the fittings. Secured both lines together with stainless steel clamps with rubber tubing placed underneath the clamps.
Applied thread sealant to the fittings on the Floscan, Fuel Valve 4161089 and the Gascolator, and tightened the AN818-6D fittings. Also applied thread sealant and tightened the connection to the F-1204D Center Section Bulkhead fitting (part of the fuel return line). Applied toque seal on the fittings I tightened today. Hopefully, there will be no leak so I don't have to redo..
