Brief Description: Installed Oil Tank an Battery Mount Braces
I had thought of installing an alternate engine but decided to stick with the Rotax. There is not much experience with the other engines and I do not want to be a Beta tester, wait for more experience to accumulate with the other engines or make modifications to my current build.
Removed the F-1240 Upper Fwd Fuse Skin so it will be easier to install the oil tank braces. Riveted the F-1201 Oil Tank Side Braces to the firewall and then riveted the F-1201F Battery Mount Brace, F-1201Q Battery Mount Angles and F-1201G Oil Tank Braced to the Side Braces.
