Brief Description: Installed nutplates to Panel Base, Canopy Ribs, et
Went back to Section 29-04 to finish the steps I skipped. Painted the part of the Panel Base outboard of the Canopy Ribs and the F-1202J Instrument Stack Angles with Rustoleum hammered silver finish to match the paint inside the Fuselage. Riveted nutplates to the Strut Attach Angles, the Canopy Rib Flanges and the aft flange and web of the Panel Base.Riveted the F-1202M Canopy Attach Doublers to the Canopy Ribs. Riveted the WD-1204 Engine Mount Brackets to the Panel Base. Riveted nutplates to the aft flanges of the F-1202J Instrument Stack Angles and riveted them to the Panel Base. Riveted the F-1202K Instrument Stack Supports to the Panel Base and inserted snap bushings to both parts.
