Brief Description: Repositioned the brake lines in the tunnel
While working on the fuel lines I noticed that the brake lines were not in the correct holes in the F-1203A Bulkhead. I thought about this for a while and tried to decide what to do. It was a lot of work to do the brake lines, specifically putting the fittings at the end. I was afraid I had to replace the 2 lines. I decided to disconnect the Fwd ends (attached to the Brake Master Cylinders) on the left side and cut the tips just aft of the ferrules (sleeves). I was then able to remove the nuts and then pull the lines back and insert them into the correct snap bushings (holes). Ordered new brass inserts and ferrules from Van's and will redo this step later.
