Brief Description: Fabricated the Fuel Line Pump-Valve
Got the ATO-035X3/8 aluminum tube I ordered from Aircraft Spruce and started work on the F-1259E Fuel Line Pump-Valve. Installed the nut and sleeve and then flared the fuel pump end. Made the S bend and then inserted it through the Center Secrtion Bulkheads. This was an effort. Marked the spot where I will cut the fwd end of the line but will finish it later.
