Brief Description: Painted Fuse Skins and inside of Fuselage
Painted the inboard surfaces of the F-1270 Fuse Side Skins. I sprayed Rust-Oleum Silver Hammered Finish using an electric HVLP sprayer I got from Harbor Freight. This is the first time I used this sprayer the coating was thick in certain areas. I must have been slow in fanning the sprayer. It was hard to see how much was being deposited while spraying. Clecoed the Longerons, Canopy Decks and the Fuse Skins to the Fuselage Assembly. Riveted nutplates to the left Fuse Skin and partially riveted it to the assembly. Will finish riveting this part tomorrow. Also riveted the left F-1234 Canopy Deck and the left F-1205A Roll Bar Attach Plate to the fuselage assembly.
