Brief Description: More work on the Right Extension
Drilled #30 holes in the right Extension into the W-1204E-R Fwd Wing Tip Rib. Match-drilled #27 holes for the LN-200 Nav/Position/Strobe Light Bracket. Cut an oval opening for the Molex connector using a rotary cutter and filed the edges. Countersunk the 6 holes in the upper flange of the Extension. Attached the LN-200 bracket to the Extension. Connected the WH-B211 Ground Wire to the access opening. Installed Molex pins to the WH-B211 Ground Wire and WH-B212 Nav/Strobe Power Wire in both wings. Inserted the wires into Male Molex Connector Housings.
