Brief Description: Work on wiring of left wing lights
Received parts from Aircraft Spruce and was able to finish this section. Attached the WH-B212 Nav/Strobe Power Wire and the Ground Wire to the rightTerminal Bracket. Installed a terminal to the other end of the Ground Wire. Reinstalled the Terminal Bracket to the Nose Rib.
