Fabricated an A-1206 Pivot Bracket. Work was very slow. My multi-function tool with a half-moon blade cuts so slowly. Maybe I need to get a new blade. Did a lot of grinding and deburring to trim the piece to final size. Drlling the hole with a 11/32 bit was extremely slow. The bit catches and stops frequently and had to reverse it and then start again. This happened numerous times. Tapping the hole was actually the easiest step.
