Brief Description: Preparation of wiring of R wing lighting system
Made a WH-B212 Nav/Strobe Power Wire, WH-B213 Pulse Power Wire and WH-B214 Landing Light Power Wire and threaded them through the snap bushings in the Ribs. While attaching the wire terminals to the Terminal Bracket, I could not fully tighten the nuts of 2 screws, even with a lot of force. Either the parts are defective or they did not seat properly. I ended up stripping the slots in the screw heads. I will have to order replacements and figure out a way to remove the the nuts.
