Brief Description: Primed parts and worked on Tie Down.
Primed the Attach Angles and Rib Doublers. Drilled and tapped the AEX Tie Down on the W-1206-R Spar Assembly. This was really slow work. The drill bit binds and stops frequently when drilling the Tie Down, even at low speed.
