Reassembled the primed Pushrod Assembly and riveted the Clevis Plates to the Pushrod. Also riveted the Threaded Insert and installed the MM-3 Bearing. Threaded the Pitch Trim Servo to the Assembly to check for fit and removed it. I will permanently install it when I put together all the tail parts later, maybe in a hangar somewhere.
