Brief Description: Hinge Brackets attached to Bulkhead Assembly.
Completed page 10-04 with riveting of the Hinge Brackets (F-1211C) and Flange Bearings (VA-146) to the F-1211 Assembly. The pneumatic squeezer is wonderful and the process was pain free. The only problem was inserting the SB-437-4 Snap Bushing into the hole. The hole is a lot smaller than the bushing and it broke while I tried to 'force' it into the hole. I will need to get a replacement and check with Van's if I missed a step (e.g., needed to final drill/enlarge the hole).
