My RV-12 Build Log
Date:  9-4-2009
Manual Reference:  10-02
Brief Description:  Fuselage Frames Assembly
Assembled the parts that were primed yesterday. First, the plastic F-1208A Wear Plate was riveted to the F-1208-R Frame and then the Right Frame was riveted to the Left Frame. The F-1209 Left and Right Frames were also riveted together.
Match drilled holes into the F-1210C Angle and final drilled # 12 holes in the F-1210B Plate, and deburred the holes. Joined the F-1210A Left and Right Fuselage Frames and riveted the Plate and Angle to the Frames.
Riveted Frames.
Riveted Frames.
Close-up of riveted Plate & Angle.
Other side of riveted Plate.
