Checked the main landing gear nuts. The nuts securing the U-1203 Inbd Main Gear Attach Brackets are still tight. The AN4 nuts are still tight at 90 in-lbs. The AN6 nuts were tight at 240 in-lbs (20 ft-lbs). The AN5 nuts at the U-1202 Outbd Main Gear Attach Brackets were not tight. These were tightened and torqued to 180 in-lbs (15 ft-lbs).
Removed the landing light lens to clean the area behind it and to put clear RTV sealant between the lens and the wing skin.
