Brief Description: Silent Hektik Voltage Regulator Upgrade
Attached the Cowl-00011 NACA Scoop to the cowl top with flox epoxy mixture. Connected the yellow generator wires to the regulator. Inserted the P3070 Warning Wire pin to position 9 of the EMS 37 d-sub connector. Secured the loose wires with tie wraps and lacing tape
