Brief Description: Primed stabilator ribs, installed nose fork
Primed the HS-1204, HS-1206 and HS-1208 outboard stabilator ribs.
Raised the nose gear and removed the old nose fork and wheel. Installed the new WD-01230-1 Nose Fork and tightened the axle nut to around 18 lbs. Greased the bushing prior to installing the nose fork.
