Brief Description: Horizontal Stabilator Service Bulletin
Started work on SB 18-0202, Potential cracking in the horizontal stabilator front spar. Loosened the turnbuckles connecting the horizontal stabilator cables to the stick assembly. Disconnected the cables from the WD-1207 and WD-1208 Stabilator Horns. Disconnected the stabilator from the tailcone assembly and then removed the counterbalance arm from the stabilatory assembly.
