42G-02: Riveted the F-00054 Inst Stack Angles and the F-00055 Com Support Brackets to the Panel Base. Re-installed the Power and Switch Module to the Center Panel. Attached the Inst Stack Angles to the left, center and right panels.
42G-03, 53-06: Installed the Garmin GTR tray and ADS-B Brackets to the Com Support Brackets and Inst Stack Angles. Organized the harnesses and placed in the snap bushings and the Com Support Brackets. Placed tie wraps where recommended.
42M: Installed the connectors to the AV-50000A Control Module and the other modules. Sprayed DeOxit Gold on the connectors.
58-05 and -06: Installed the SV-Knob Panel Modules.
Removed the FC-403 Intercom since the GTR 200 has a built-in intercom. I'll need a larger cushion clamp that will hold the harnesses on the left side of the Panel Base. I also need to get a new BNC connector for the antenna.
