Added reinforcing glass to HS fairing. Drilled and riveted nutpaltes to HS for fairing attach. Removed all hardware from doors and painted ith smoothprime. Rivieted upper cowl hinge in place. Drilled and riveted nutplate for cowl pin tab. Riveted panel side brackets. Fit and adjusted cowl pin cover. Added form flox/epoxy to some defects in cowl.
