AFter soem inspection, the nose gear fairing is off-center. Contacted Vans and Matronics list and most said it was OK, but I couldn't take it. Spent today sanding off braket support pads and re-fitting fairing to nose gear. This is going to require some fiberglass repair to fairing, but should make is look better, be more aerodynamics (i.e. less rudder), and cause less damage to faring when towed (by line service). After re-fitting, I added new epoxy pads.
