Brief Description: Install Fuel Filter, Pump, and Transducer
Got a fuel line from Bonaco that was cut shorter so wokred on fuel system. Install fuel boost pump, fuel filter, Red Cube fuel transducer, and assosicated fuel lines that were cut at Bonaco. Will need to final install FF transducer bracket at later date as stick location does not work. Will also need to reinstall elevator rod harware as it had to be removed to install fuel lines.
