Brief Description: Drilled holes for VS hinge brackets.
Tonight I was able to work for a few minutes and match drilled the holes in the upper VS-410PP hinge bracket.
The pictures below show the parts needed for the rear spar included the doubler which adds strength and the hinge brackets that the rudder will mount to and pivot on.
I forgot to mention this in the entry for this morning, but I installed an eye bolt in the wall of my bar area and hung the horizontal stabilizer so it is now considered "art". I plan to hang all of the tail components on the wall and the wings from the ceiling. The fuselage will be able to stay in the garage because when it is done I will install the engine, radios, interior etc. and then it will be time for final assembly.
