Brief Description: Started vertical stabilizer (VS)
Today I pulled out some of the parts needed for the vertical stabilizer (VS). This is the fixed part of the tail that sits up and down (vertical, duh) on the end of the fuselage. I clecoed the rear spar and spar doubler VS-808PP together along with the hinge brackets for the rudder, VS-410, 411, and 412. The parts fit good and I am anxious to be working on another component instead of the HS.
