Garys RV-7 Builders Log
RV-7
Flap actuator work
Today, I drilled and cut the F-680 flap bearing block. I then drilled the safety wire hole in the ES-85615-157 flap actuator. I also mounted the WD-613-EF flap actuator weldment and marked the holes using the F-680 block holes as a guide.
RV-7 Home
880
Airplane and Flying
All Things Aviation
161
Family and Non-Aviat
Finishing Kit
530
Paint Related Items
Practice
Shop Set Up
187
