Brief Description: Center cover and fuel valve mount
Tonight, I bent the cooling louvers on the center cover. I then painted the fuel valve mount, center cover and access plate.
Next, I started work on the electric flaps. I drilled the clevis ends of WD-613-EF to 1/4". I then located F-680 nylon block before calling it a night.
