Brief Description: Install lexan braces & Rear floorr pan
Install Lexan braces, which turn out to be aluminum tubes parallel and on each side of the root tube
Install front and rear cross bars to left and right belly rib then fit over belly ribs and cross bars - drill and install 22 rivets to front and rear cross bars
