Brief Description: Install trim adjuster handle, differential plate a
steps 10 & 19 have been deferred due to a part not yet received
Steps 22, 23 & 24 have been deferred due to parts not received
Step 25 is complete except the control rod needs to be bolted on as soon as the end eye bolts arrive which have now been reordered.
Because of a right shoulder issue, I have choosen to install the trim adjuster handle on the left side of the root tube. Accessing the handle from the front seat requires a long reach upward and rearword, which will be much easier using my left arm. It is nice to be able to adjust the aircraft to my personal advantages . . .
