Brief Description: Riveting HS-710, HS-714 to HS-702
Got one rivet set in this assembly. The second was slightly unsatisfactory, so I drilled it out. The second was much more unsatisfactory, so I drilled it out too. Now the hole is expanded, and I need to decide if I need to go with a larger rivet. Pausing for a breath.
