The exhaust goes into CAMIT 3 into 1 collectors on each side fo the engine. That is all good but I need to make the pipe down to the augmentor and the heater boxes. This is made from stainless pipe and stainless sheet. I machined the end bulkheads for the heater boxes a couple of months ago. The pipe is straight sections and pre bent 45 degree sections. The job is simple just cur and file the sections until it all lines up with the exhaust outlet centred in the augmentor pipe. Simple. Oh and hold it all there so that Alan can weld it all together up in Sydney
So I made a fixture that plugs into the augmentor tube and clamps to the 3to1 collertor. This fixes the two end snd then make the pipe work fit together btween these two points. Then fabricate the heater tube which are round with an inlet and outlet.
Anyway it all came to gether pretty well.
Pipe and heater in place. Oil cooler and outlet duct behind
The oil cooler pick off is center right. SCAT this to the heater port
