Brief Description: Exhaust System and lower cowling
Cut and manufacture the exhaust system from the collector to the outlet. Including the two exhaust pipe muffs. One for carb heat and the other for Christines cabin heater. I also added a fibreglass extension to the lower cowl mount. I had to raise the engine a couple of degree's to get it closer to level. This has ment changing the cowl mount. Worked out OK.
Lower cowl extension
Fibreglass extension to the bottom cowl
Cutting the stainless steel end plates fo rthe muffs
