My earth journey takes flight
Date:  8-9-2014
Number of Hours:  3.00
Manual Reference:  6-W-2
Brief Description:  Riveted Right Ailerons
Riveted the right alieron together. I just left the top skin outboard forward section so i could check fit and adjust the counter balance arm if required. I didn't rivet the left aileron since I want to install the aileron trim and I don't have the parts for that yet. I checked the calibration of my torque wrench doing some math and using electronic scales. Better than not checking it I thought. This was used to torque the lock nut holding the balance arm inside the aileron.
Riveting the right aileron
Calibrating my torque wrench
Torquing the balance arm bolts
