Brief Description: Left Wing - L Angles and Tip Access
I fitted all the upper skin L Angle stiffeners to the left wing. These are part of the B Mod upgrade. I also added two L angles in the rear portion between ribs 4,5,6. This extended the aileron pivot stiffening between rib 6 and 7 inward to the wing walk area. These two areas are very drummy as this area is relatively flat and large. The locker also contributes to flexibility in the skin here.
The tip access is required to inspect and adjust the aileron counter balance weights added by the B mod upgrade. It also provides access in behind the wing tip strobr if required and you have a double jointed elbo
