My earth journey takes flight
Date:  6-28-2015
Number of Hours:  12.00
Brief Description:  Dual Throttles
I have been thinking about the throttle for a long time. The cockpit has the joystick in the centre now and therefore the throttle needs to be on the outside, both sides. I wanted something in a comfortable position that was even witht he centre stick just aft of the main spar or knee line. You need to have the throttles joined at some point. So I went with having a torque tube running across the front of the spar. In the centre console an arm drives the cable to the throttle body injector. The mountings also hold the fuel line running in from the wings. I will do plenty of testing on this yet as it needs to work flawlessly.
Full throttle
Full throttle
Idle
Idle
With cover
With cover
