I purchased conform foam to make the seat cushions. The foam is energy absorbing and fire rated. The seat is made up by gluing the layers together. The pink foam is the softest then blue, then grean which is firm and only located under your bum. Its like memory foam but specifically designed to absorbe impact energy without rebounding. Hopefully we never need to test this.
Cutting the foam to creat the shape
Christine testing the seat
Christine will need some extra foam so she can fit comfortable int he seat.
