Brief Description: Canopy - Drilled Perspex to Frame
Today was a mild Australian summers day of 33 deg C. Perfect for drilling a perspex canopy bubble. The first hole is the hardest. It all went well so far. All holes drilled to pilot size. Net warm day I need to go back and expand the perspex hole to 5/16 as per plans. This gives space for heat expansion for the perspex near the mounting screw.
Good to sit in although the perspex still has the protective plastic on it.
