I fabricated the centre console. The base has the mounting for the gascolator which will go through the floor of the cockpit. The base is also a drip catching tray for the fuel selector, gascolator and electric fuel pump. All this plus the fuel flow sensor will be the centre line of the cockpit side of firewall. Fuel selector goes on the flat section as seen on the mockup
Gasecolator will be right at the lowest loint of the fuel system. Electric pump just upstream of that so it won't have to suck fuel. Should keep the fuel cooler this way. The gascolator exits the fuselage directly behind the main undercarriage (Tail dragger)
