Brief Description: Re-Installed Filight Control Tube
Re- installed the main flight control tube in the the centre cockpit. I have converted it back to centre stick now. The B-Mod control stops as designed by Zenith do not fit well and will make installing and inspecting the aileron control cables more difficult. This area is going to need looking at. I can't really install them as they are. The stops provide for a hard limit on stick movement left and right. Giving it a bit more thought I am sure something much simpler and less likely to foul the control wires would be possible.
