Started teh day marking and cutting sheet alminium to make the centre soncole side panela and the dash board skin. Once I had the shape I transfered the rivet holes from the damaged parts. Then fitted the new parts in place. Fitted the centre spar and under body double. The rear uprights where more damaged than I expected so I will have to get replacements. A good days work, mostly forward progress :)
